- Oct 23, 2006
- 48
Just cleaned stove and flex. chimney liner. It's clean throughout. Stove starts and runs fine. Pellet feed is fine.
Blower fans run perfectly on High setting. After about 20 minutes or so I turn the blower to Medium. Fans run OK. Then later on Low setting fans run for a while, THEN STOP. Feed slows, etc.
Then I turn the fan to Medium, no blowers. After about 5 minutes the Medium speed starts again. Back up to high fans OK. sounds like a heat sensor problem.
Dealer mentioned problem could be Snap Disc -- #2 possibly.
Ceramic thermo. is tight against wire in burn bot.
Anybody have experience with this problem?
Trying To Keep Warm
Trying To Keep Warm
) Hey, I have two so I have to live with my choices. Once they are out of warranty, I am toying with the idea of putting a better controller on them that gives me more control and choices.
! I've been saying all along that you don't have enough heat on low to maintain a consistent draft/vacuum. Your flame on HIGH should be 4-6" above the fire pot. Of course, it varies but that's a good average height. When I changed brands of pellets, I had to readjust my feed slides on both stoves from almost closed to almost wide open, so pellet brands make a big difference. I asked the question earlier - when you started having problems last winter, did you change brands by any chance?
