Quadrafire 4100i cracked rear secondary air tube
Locust99
113
Upstate, New York
I recently purchased a used quadrafire 4100i. Overall the stove looks to be in good condition, but there is a crack in the rear secondary air manifold. Is this something that needs to be fixed or can the stove be run with this?
Thank you.
  • [Hearth.com] Quadrafire 4100i cracked rear secondary air tube
It should be fixed or it will only get hotter there and get worse. Hopefully there is enough metal there to weld a patch. In the least temporarily plug it with some furnace cement.
Quadrafire makes a repair kit for most of their stoves to fix that issue.
Do you know where I could purchase the repair kit? I can’t seem to find it searching on the internet. I did sent Quadrafire a message about this though so maybe they can provide me with a p/n to order. So hopefully I can find a repair kit or a welder.
A quadrafire dealer.
I have a Quadrafire 3100i with the same issue. Though I have to say my rear manifold is more than cracked. It looks like a small charge went off behind the joint, exploding into the firebox. I contacted a dealer earlier this week. THey asked for the serial no, and did some reasearch. They called back to tell me that (a) this is a warrantied part (at least on my stove); (b) the part is a repair kit that may require some welding; and (c) it's free from QF if you have warranty info (proof of purchase, etc.). Labor is on your nickel.
Does anyone have a picture or drawing of this part? Before proceeding, I'm curious what it looks like, and what installation will require.
Thanks in advance...
