Quadrafire Classic Bay Flame height Setting?
Don2222
9,244
Salem NH
Hello
Well not sure if this is the best setting but I do not want to overfire the stove.
Currently I have the Hopper Feeder set to 30 and with the Heat Level switch on Medium Heat see the flame.
I originally set it for 40 and that seemed high? Should it hit the heat baffles alot?
see height below:
Is that good? OR What should it be?
  • [Hearth.com] Quadrafire Classic Bay Flame height Setting?
Stove should be on High when you set it. In the manual it states to make small adjustments (waiting 15 minutes in between adjustments/ It takes that long for your adjustment to be seen in flame.difference / Auger is full of pellets at your last setting, takes time for auger to fill with that "setting")
Until the flame hieght is 4"-6" above the pot. Thats per manual.
A change in pellet will require a slight adjustment. No 2 stoves will have the same setting.
The flame can "lick" the top baffle plate here and there. But I only like to see it on start-up.
If set properly, the baffle plate is just at 6" over very top level of firepot. So it shouldn't hit it often. Flame on that steel may cause warping. I know there have been some warping issues in some Quads. Not sure of all models though (Mt. Vernon is one of them).
Until the flame height is 4"-6" above the pot. Thats per manual.
Thanks for all the information.
I increased the setting a little over 30. That seems to be good. That should also put a few more pellets in the fire pot when starting. I had a couple false starts this morning at 43 Deg F in the shed. I went out there and found that even though everything was working fine that not enough pellets were dropping down the chute. I am using Maine's choice hardwood pellets and some are kinda long. So opening up the feeder a bit should help!
Well we are looking at 19 Deg F in the morning so I can do more cold weather startup testing. I am not convinced it is the capacitor since the Auger seems to be working well.
