Hello,
I have benefited from the expertise on this site in the past with my stove and am in need of help again please! Before firing up my Contour stove for the first time this season I cleaned it (I clean at the end and beginning of season) and loaded fresh pellets in. Plugged unit in, call light on, control box blinks but that's it...no exhaust fan, no feed motor activity. So I made a jumper wire and tested snap disc #1--result--convection blower came on, but no exhaust fan or feed motor. So I tested snap disc #2-same as initial start up, no blower/feed motor activity.
Then I jumped the Vacuum switch-the feed motor came on and fed pellets, but no exhaust or convection fan activity.. After 5 minutes I opened the door and the firepot was warm to the touch. I kept the jumper wire on and the unit powered up and then 10 minutes later the exhaust fan suddenly turned on. No fire in the pot at this point and the call light was still on. Exhaust fan ran for approximately 5 minutes, then turned off. So I pressed the reset button, feed motor fired up as did the exhaust fan. After a few more minutes I had a fire. Feed motor and exhaust fan stayed on and after 7 minutes the convection blower turned on!
Is it safe to assume that the only problem is a faulty vacuum switch? Also how safe is it to continue to run the stove using the jumper wire in lieu of the vacuum switch? If anyone could offer some advice please do so. I called two 'local' dealers and the soonest they can get someone out to charge me $265 to look at the stove is December 10th....!
Thank you all in advance for your help!
Bill
Bill
