Question Installing my VistFlame VF-55
Curve
47
Central, MA
I am installing my pellet stove today and ran into a little issue I need help with. I came off the back of the stove with a 4" T cleanout, and then into a 36" piece of straight pipe, and than a 90 elbow that I am trying to fit into an adapeter to my 8" MetalBestos Chimney adapter. The issue is that the elbow is about a half inch short of reaching the 8" adapter. What is the recommended way to make this work?
Adjustable pipe
Hello
I did something very similar. I went from a 4" pellet pipe into a 8"x8" block chimney. It takes a 4" to 8" pellet pipe adapter and then straight pipe that should go into the middle of the chimney.
I did use an adjustable pipe on the horizontal to go the correct distance.
See pic below. Click to Enlarge.
  • [Hearth.com] Question Installing my VistFlame VF-55
I have 1 piece of 12" adhustable pipe. If I put this on the 36" piece, will I be able to slide it all the way down so that only about half inch is left over? I wasn't sure that this adjustable piece would slide down that far.
hi curve.your best bet is a 24' straight pipe and an 18' adjustable.you havnt fired it up yet so hopefully dealer will swith the pipe for ya .good luck.cant wait to see pics
