The existing propane system would be used as back-up and I have no plans of getting rid of that system. It's a single zone for the house with a nice high efficiency boiler that was installed in 2023.
I'm hearing a lot of support for the Blaze King and I can understand why after doing some more thorough research. I really do like the hands-off approach that the BK would allow (especially) with two littles I'm constantly chasing after.
One of my main concerns that hopefully members of the forum can shed some light on is the new liner. Am I setting my self up for obsolescence putting an 8" liner down to feed the BK? As I will need to put a new liner down regardless of the stove I'm putting in. As begreen mentioned, why is a 6" liner recommended for a new liner installation?
Side note, but I've also extensively looked into getting a wood boiler to tie into the existing system hot water heat system, but most the systems I looked into were upwards of 10 to 20 grand depending upon manufacturer and size of the system. The indoor wood stove would act as a nice bridge to get me to a fancy wood boiler system in the future. Or if anyone has any indoor wood boiler recommendations that would be awesome.
I would not put in an 8" liner these days unless it was the only option or required to connect a specific unit. In this situation, it's an unwarranted expense. Instead, I'd put any savings into insulating the basement walls and sealing the sill plate first. Then, a good ~ 3 cu ft stove will suffice to heat, especially considering it is just for backup. There are lots of options to choose from in that range depending on the budget.I'm not sure why @begreen said any new liner "should be" a 6" liner. They sell 8" insulated liners too. Especially with a liner, it could always be removed and replaced with a 6" liner if in the future you felt it was needed for a different appliance.
I would normally say you must be joking, but I know your not. Is the crane still thereSorry for any confusion, but I plan on using the wood stove as the main source of heat for the house during the cold months of the year up here. There is a propane boiler that can be used if needed, but I would rather not pay the full propane bill.
I did just find a small hiccup that might throw a wrench into my plans. For some background, the previous owner and builder of the house was a very handy machinist. I was doing some more snooping around and found that the chimney pipe inside of the chimney is a SOLID piece of heavy gauge steel that runs the entirety of the chimney. The existing pipe is uninsulated and is a 6" diameter pipe.
I remember the daughter of the owner telling me they lowered this piece in with a crane. So, that being said it seems my options are pretty slim with this new found information.
That stuff would be expensive but I guess he got it at wholesale. That will be around longer than me, but I wonder how much creosote you would get as you try to heat up 2000 lbs of steel in winterFor some more context... Here is the "barn" that came with the house. Note the SOLID steel chimney that is on the left side of the barn. Something very similar (although it is on the interior) exists for the house as well.
That stuff would be expensive but I guess he got it at wholesale. That will be around longer than me, but I wonder how much creosote you would get as you try to heat up 2000 lbs of steel in winter. I think that one will end up as a flag pole.
That will be an interesting conversation given that the insurance companies have picky engineer underwriters..ie must be to codeSorry for any confusion, but I plan on using the wood stove as the main source of heat for the house during the cold months of the year up here. There is a propane boiler that can be used if needed, but I would rather not pay the full propane bill.
I remember the daughter of the owner telling me they lowered this piece in with a crane. All of the thimbles (one for the wood stove and one for the sauna stove) are welded on to the chimney and the chimney pipe looks to be in good condition. So, that being said it seems my options are pretty slim with this new found information. The only feasible route ahead that I could see being an option is using a product like a chimney insulation mix to keep the thick gauge steel properly insulated. Otherwise I might be stuck just using the system as is after an inspection.
Update: An old timer that has been in the chimney repair and inspection business for 50+ years is going to stop by to give me an opinion. I'll post back on here when swings by.
Oh we have a sauna? Cool. I used to have one. Many memories.Your saying the sauna and the wood stove are on the same flue? I'm not sure that would pass code.
Looks like I crossed your posting with another, my bad, sorry.Sorry for any confusion, but I plan on using the wood stove as the main source of heat for the house during the cold months of the year up here. There is a propane boiler that can be used if needed, but I would rather not pay the full propane bill.
BG, you have to go back as few post and see what the OP has for chimney(s). It is most unusual.Looks like I crossed your posting with another, my bad, sorry.
Still, there are many stoves that will provide an easy 8-10 hr. burn time that will work on a 6" flue, especially burning hardwood. The BK Princess, Regency 3500, Lopi Liberty, PE Summit, Drolet (Escape 2100, HT-3000, Myriad III, etc.), Quad 5700, are some examples.
Honestly I would probably cut the steel pipe with a torch at the bottom while someone pulling it away from the barn. This will alow
You to start from scratch and have a very efficient chimney. You could scrap or repurpose that pipe.
Unless that steel pipe goes deep inside the barn as well?
That’s to make sure it was straight, and deep into the ground. It really wouldn’t be hard to torch it off at ground level.The pipe required a crane to put it in, I don't think removal would be that easy.
If that type of pipe is in the masonry chimney, then I’m sure you’ll need a craneThe photo posted of the barn is just for reference. The actual project I'm concerned about is the house. The barn is another story...
I think a crane would be required to remove the chimney pipe inside the house. It's likely about +2000 pounds of steel. No word back yet from my inspector.
