pendulum said:
firefighterjake said:
Thought this might peak some interest . . . personally I have mixed views on this issue.
http://www.mainelegislature.org/legis/bills/bills_124th/chapters/PUBLIC250.asp
Since it was adopted in late May I imagine this will go into effect some time in August.
i wanna hear your cons, intelligently expressed,denoted,annoted
Actually my only con is the way this was done . . . legislators superceding fire codes that have been adopted after a long process involving many involved parties on a committee and then approved by an even larger body (i.e. the NFPA method of formulating and adopting and modifying fire codes) isn't always a good precedent.
In my own opinion, a better way to make a change would be to fix the code . . . if there are no true reasons for the two-flue rule (i.e. good science showing the danger vs. junk science or a commonly held belief) then the code should be altered and the majority of the membership should be able to see the reasoning behind the change. Having legislators vote to change code for convenience sake isn't always a good idea . . .
That said . . . I honestly don't know if there is a true, valid reason for the two-flue rule or not . . . in fact our Fire Inspector isn't quite sure . . . and even a contact in the State Fire Marshal's Office has made some inquiries and isn't quite sure if the alleged reasons for the rule are truly valid or not. In my opinion, if the science doesn't reflect a potential problem the rule should be nixed . . . but if the science shows a problem the rule should stay . . . but in either case I would validate the opinions of a bunch of professionals in industry, fire safety, etc. (i.e. the NFPA committee that covers this set of codes) vs. a bunch of politicians who want to keep their constituents happy.
