I'm replacing my old VC resolute acclaim with a Woodstock stove (either Ideal Steel or Absolute Steel) and am trying to figure out whether top or rear vent configuration will significantly affect the stove's performance. The thimble on my chimney is about 42.5" high (center height) and about 12" behind where the back of the stove will go. So I have a couple options:
Assuming it's a wash on exhaust, any thoughts on the Absolute vs Ideal Steel in general?
Thanks!
- If I get an Absolute Steel "High Style" and place it on a 1.5" thick hearth pad, its rear flue exit will line up horizontally with my thimble. Then I can connect a 12" section of pipe (or maybe a 6" section + a double male connector?) directly between them.
- With an Ideal Steel, I think I can adjust the legs to a height where a 90-degree elbow directly on top of the stove can connect to the 12" horizontal section.
Thanks!
