Thanks for all the great information on wood stoves! I'm posting some pictures of my install to return the favor. My application is a masonry fireplace with full clay liner. Had it cleaned and inspected before the install. Stove is a Quadrafire Cumberland Gap. I decided to use the rear vent feature so I could exhaust through the existing fireplace.
![[Hearth.com] Rear vent wood stove through masonry fireplace [Hearth.com] Rear vent wood stove through masonry fireplace](https://www.hearth.com/talk/data/attachments/104/104692-d745b9fde7a680c262078be8a296523f.jpg)
I extended the existing hearth by 24" to get the required clearances. My hearth extension is two pieces of flagstone floating on 1/2" Micore 300 mineral fiberboard. BTW I have a couple pieces of the Micore left if anyone near West Chester PA needs any.
I got a stainless steel flexible chimney liner, insulation kit, and stove pipe from Chimney Liner Depot. I removed my fireplace damper plate and cut out a small section of the damper plate frame to let the liner pass through.
![[Hearth.com] Rear vent wood stove through masonry fireplace [Hearth.com] Rear vent wood stove through masonry fireplace](https://www.hearth.com/talk/data/attachments/104/104695-5100d450b88f2c2d913f464bdee0821b.jpg)
![[Hearth.com] Rear vent wood stove through masonry fireplace [Hearth.com] Rear vent wood stove through masonry fireplace](https://www.hearth.com/talk/data/attachments/104/104696-3af0dab66090f3b8341cfb4838c72185.jpg)
Connected the tee and the tee cap to the flexible liner.
I used some of the leftover Micore 300 to block off the damper opening around the liner.
![[Hearth.com] Rear vent wood stove through masonry fireplace [Hearth.com] Rear vent wood stove through masonry fireplace](https://www.hearth.com/talk/data/attachments/104/104700-68fc84e2d3081852932742ec7064cb21.jpg)
Then I added the snout and moved the stove into place.
![[Hearth.com] Rear vent wood stove through masonry fireplace [Hearth.com] Rear vent wood stove through masonry fireplace](https://www.hearth.com/talk/data/attachments/104/104697-ced0164a57c8410dfffbf27d8ec24d56.jpg)
![[Hearth.com] Rear vent wood stove through masonry fireplace [Hearth.com] Rear vent wood stove through masonry fireplace](https://www.hearth.com/talk/data/attachments/104/104698-737c6eb40735b0d925628e71fff92d1b.jpg)
Moved the stove into its final position and made the connection to the stove pipe. Hope this helps someone!
![[Hearth.com] Rear vent wood stove through masonry fireplace [Hearth.com] Rear vent wood stove through masonry fireplace](https://www.hearth.com/talk/data/attachments/104/104701-cfb3e42c36a552985f9d192a06920049.jpg)
![[Hearth.com] Rear vent wood stove through masonry fireplace [Hearth.com] Rear vent wood stove through masonry fireplace](https://www.hearth.com/talk/data/attachments/104/104702-45c701da097defcd4a8c58e4b700da6c.jpg)
![[Hearth.com] Rear vent wood stove through masonry fireplace [Hearth.com] Rear vent wood stove through masonry fireplace](https://www.hearth.com/talk/data/attachments/104/104703-7be6ab3d9a395b2c44e223a0e2b326d6.jpg)
![[Hearth.com] Rear vent wood stove through masonry fireplace [Hearth.com] Rear vent wood stove through masonry fireplace](https://www.hearth.com/talk/data/attachments/127/127347-189f4f7164d790ce0a3b5ca71400314e.jpg?hash=CWwIHwULWC)
