Depending on the boiler you end up finding or deciding on, you might not 'need' the storage. Many can operate OK without it. But they all would work a lot better with it, and maintenance goes up without it. Leave provisions to add it in later if you think of going that route. Also keep in mind in the planning other uses you could make of the boiler building - a warm workshop might be nice to have for other things, or if nothing else you can keep your winters wood warm & dry all winter. i.e., make sure its lots big. I suspect the ROE on this one will come down to your scrounging ability & just plain luck in finding things. Good luck!
(Also, check in at the classified section on this site once in a while, some good things do pop up from time to time).
