Hi all,
We have had issues with our chimney since we moved into the house some years ago, and finally had a chimney sweep run a camera through both flues. We have motor missing between many flue tiles, so we would need each flue relined for use.
From what I gather, it doesn't seem to make much financial sense to reline the flue just to use it for an open fire, so I am considering getting an insert. I've researched quite a bit, but figured I would make a post asking for recommendations.
I don't plan on using the insert as a primary heat source. I live in Virginia, so the winters are mild - but, supplemental heat would be nice to offset my heat pump during the cold nights. The chimney sweep quoted us $6200 for an install of a Regency CI2600 ($3700 for the stove, $2500 for the install). My quick research online makes me think that price is a little high, but even so I'd prefer not to spend more than $5000. To give you an idea of my chimney height, the sweep said I'd need 25' of liner.
I do like the flush and simple/sleek look of the Regency CI26700. Another example of the style I like is that FireplaceX Large Flush Rectangular.
If it helps, my fireplace opening is about 36" wide, 24" high, 24" deep, with the back wall 30" wide.
Thank you!
Thank you!
