First serious burning with my new epa insert and find that the temp gauge on the top is only accurate some of the time(see post in the gear forum).. Anyway, after the secondaries have finished, I go outside and see no smoke. Often as long as 2 hours after the secondary burn has stopped I still see no smoke, but tonnes of heat. Tapped and smacked the gauge and got it in even sync with the oven test, and often when it only reads 300-still no smoke.
So my question for those of you who have burning the epa stoves and inserts for some years is--Can one assume that if you don`t see smoke, you are not accumulating much creosote? Specially when in this case, the glass seems to stay nice and clean.. Just thinking that no dirty glass means burning hot enough and clean enough?
This insert is not a "cat"..
