Regency F3100L glass question
Gwilkrrs
17
Maryland
so still new wood burner here.....
i am good running the stove during the day and the glass stays clear,
i run the stove to ignite the logs well before pushing in the air rod for the night- i pushed it in all the way last winter to choke the fire down for the night- this year i only pushed it into the 2nd notch on the bar so still out aways from choking the air off.
when i get up the glass isnt like last year but is grey with just a touch of crystals. it razor scrapes right off- not bonded like last years glass----
i even let a fire burn out during the day with the air rod out half way and it did the same.
is this normal? i keep seeing that the glass tells the story and it should be able to remain clear? is this correct and if so what am i doing wrong? the wood is testing from 5-11%
is there a protectant to put on the glass to help with this?
[Hearth.com] Regency F3100L glass question
I believe this is a non-catalyst stove. The glass should be able to wipe clean with a damp paper towel. At most, a bit of ash from the stove on the damp paper towel should take any build up right off. The razor blade should not be necessary.
Yes, in that case, just try using a damp paper towel to clean the class next time, it’s surprising how well that cleans up the surface stuff. The buildup on the glass in your picture above, doesn’t look very heavy at all and should clean up pretty easily without the razor blade.
Although counterintuitive dipping the paper towel in the ashes on cool stove can really clean up heavier build up.
About the Wood moisture content, getting readings down to 5% tells me that you’re probably not measuring the wood correct correctly. This time of year, I would bring a good representative piece of wood into your house for about 24 hours so that it’s at room temperature. Then split it and then immediately take the moisture reading on the fresh face of that split wood. That should give you the most accurate reading.
For reference, I’m in southern CT and the lowest readings that I typically get are about 15 or 16%. But usually I’m thrilled if I get my Wood to around 17 or 18%. Wood that is on the moist side will contribute to the glass getting foggy quicker. That said, even with dry wood you’re still going to get some buildup on the glass, albeit a much lesser amount.
Not to complicate matters any further, because you’re probably just fine, but you may want to check to see if your door gasket and stove glass gasket are good. For the door gasket, you can do the “dollar bill test“ . That is where you take a dollar bill and stick it in various points in the stove door area when stove is cool. If you close the door on the dollar bill and can pull it out easily, the gasket is not functioning properly in that area. If you get decent resistance and/or you cannot pull the bill out, all is well. I’m not totally sure the best way to test the stove glass gasket, but a good telltale sign of an air leak at any point in that glass gasket would be if you’re noticing heavier glass buildup in a particular spot along the perimeter of the glass than in others.
How are you texting your wood? I highly doubt your wood is getting down to 5% in maryland. Are you resplitting a piece of wood right before you test it and testing the inside? I would put my money on your wood is too wet.
For your glass, open the door and place both palms on each side of the glass and see if you have any movement up and down and/or side to side. Read that method on this forum.
No protectant. Commercial cleaners available but you must rinse it off with water after the glass is clean otherwise it will bake on.
Looking at your picture it appears the top of the glass is clean, that MIGHT indicate you have a leak across the top gasket. Thats what a leaking glass gasket looked like on one of my older stoves. Note the MIGHT in capitals, it could just be the way your air wash system works.
so i tested the glass- the glass is tight up and down and left and right.
now for the wood moisture- thanks for the education on how to test..... i pulled a piece i had stored from the garage stack and split it and tested the freshly opened face- 18%-21%. i have about 3-1/2 cords (i think) split and stacked all from the same time so i will pull a couple more from the pile..... (5' wide x 16' long x 6'tall)
Reactions: Murray01
Ok so all sounds good. Wood that is 21 percent could be a bit drier but still fine. We are currently in “shoulder season“ for using a woodstove, which means that it’s still pretty mild, especially in Maryland. There will probably be the tendency to burn a bit hotter overall in the months to come, which may reduce the glass getting dirty.
Folks on here with some better tech knowledge can tell you if there may be any issues with the air wash system.
i was amazed that wet paper towel and ash cleaned the glass!
my wife loves the glass to see the fire and expects it clear or thinks i am doing things wrong............ and i am unsure myself and just dont want to creosote the pipes......
some days the house smelt like a bbq smoke house when the wind blew just right prior to heating season.....
thanks for the help
Reactions: kborndale
Glad it worked out! Your picture above showed light color ash on the glass. That means that you are burning at a good temperature and creosote in the flue should be minimal. Just sweep it once a year and you should be good. You already know the wood is decent so you should be good to go.
