My friend bought a house and gave me his Regency R14 wood insert. It is in good shape although I would need to add a coat of paint before I would install it.
After reading the forum and other websites about wood burning inserts, I have a few questions that I hope someone can answer to help me assess if I should even pursue installing the insert.
a) I have a trim kit but would it pass WETT certification if I chose not to use the trim kit. I want to push the insert as deep into the fireplace as possible while maintaining clearances. This way, I don't have to make a dramatic change to my hearth extention. Is there any drawback or violate installation to do this?
b) My brick chimney is located on the exterior of the house. The chimney only runs about 15' from the base of the chimney. I presently have stuffed my current fireplace with insulation as there is a strong cold draft during the winter. From what I have read, I may have draft issues. Given this condition, should I still pursue installing the wood insert? Would adding a 3' or 6' flue extension help to eliminate the cold draft problem?
Any advise would be recommended.
doesn't want his Regency R14 insert and I can
