My firebox has split apart on the seam, (The pictures below will show the split) I want to replace it with another firebox but I am having trouble getting the flue on the top of the firebox removed. I can lift the flue box that sits on the top of the fireplace regulator but I can't get it high enough to slide the firebox out. I push up but not far enough to clear the regulator box on the tip of the firebox. The firebox has two angle metal bars that run the length of the firebox I have taken out the screws to the angel iron legs but the legs won't come off the box. I thought that if I removed the bars it would give me more clearance and lower the upper flew pipe from the regulator and maybe I can slide the firebox out, but I can't get the legs to come off. I don't know if this is the way to get the firebox out or not. If I can get it out I can put it on a dolly and roll it out of my house. Question: is there a special way to get the box out without pulling all of the metal panels that surround the firebox. Any help would be appreciated
Thank You.
![[Hearth.com] Removing the firebox on my El Fuego insert [Hearth.com] Removing the firebox on my El Fuego insert](https://www.hearth.com/talk/data/attachments/267/267897-0795d57ca4ca15e3413ef6a826d4f98a.jpg?hash=z-IOK46qoq)
Thank You.
![[Hearth.com] Removing the firebox on my El Fuego insert [Hearth.com] Removing the firebox on my El Fuego insert](https://www.hearth.com/talk/data/attachments/267/267892-c69728aca47b9804185f55084fcb047c.jpg?hash=6hF-kluiLj)
![[Hearth.com] Removing the firebox on my El Fuego insert [Hearth.com] Removing the firebox on my El Fuego insert](https://www.hearth.com/talk/data/attachments/267/267893-3f49ab34672ed6157f15a9226a766b96.jpg?hash=O4pq3nLNlS)
![[Hearth.com] Removing the firebox on my El Fuego insert [Hearth.com] Removing the firebox on my El Fuego insert](https://www.hearth.com/talk/data/attachments/267/267894-bc51176bee984c27a3c33b84d9aff0a1.jpg?hash=Y33wkF8fpy)
![[Hearth.com] Removing the firebox on my El Fuego insert [Hearth.com] Removing the firebox on my El Fuego insert](https://www.hearth.com/talk/data/attachments/267/267896-23d8f383f4a2c0da9ba090047a85564f.jpg?hash=Zl1Ak3GZ26)
