Replacement Liner Bricks & Stove Seasoning
emcee
1
washington
Howdy....couple q's hoping someone can help me with. remember there are no dumb questions! ;)
- We have a dutchwest wood stove (model 2477) with a couple liner bricks that need to be replaced. having a hard time finding exact replacement online. does replacement have to be the exact same shape? the one on the side door for loading wood broke into 4 pieces and is typically held on the door via a bolt that goes through middle of the brick. the shape of the brick is pretty specific to the door's shape. could i just use a square brick in its place and drill a hole through it? and are liner bricks something typically found in local hearth shops or hardware store?
- Does a cast iron wood stove need occasional seasoning similar to a cast iron frying pan?
thanks in advance!
cheers,
mc
begreen
Mooderator
Staff member
Nov 18, 2005
101,019
South Puget Sound, WA
Have you tried Woodmans Parts Plus?
cahaak
Burning Hunk
Feb 12, 2012
139
MN Twin Cities
I buy my bricks in a six pack - 9" x 4.5" x 1.25" which I believe is the standard size. They are very reasonable at our local Menards hardware store. If you have access to a tile saw or other tools like that, the bricks are quite easy to cut or drill (compared to porcelain tile). So, you can make them any shape you need to that fits.
begreen
Mooderator
Staff member
Nov 18, 2005
101,019
This stove had refractory panels, not conventional firebrick in the firebox. Long ago @tradergordo had a good thread and links to his website that showed how to cast them out of refractory cement. Unfortunately, the links and that site are no longer working.
