Replacing door handles
guudbears
6
Hudson Valley, NY
I have an Olympic Crest stove (basically a knock off of a Defiant) that I've been using heavily for thirty years. I recently had it re-caulked, repainted and re-installed after our home was remodeled. The wooden handle on the front door has just split and I was wondering how to repair/replace it specifically what cement I could use to keep it in place. Or alternately should I stick on some new spring handles and how is this accomplished? Thanks, new to the site but not to the pleasures of heating with wood.
Welcome to the forum.
Do you know any woodworkers?
Wood glue and clamp it overnight should hold until the season is over.
I have the same stove and did not like the junk wood handles so I built my own. I have acces to all things welding and blacksmithing so it is easy for me to go to the shop and fabricate anything from steel. You can go to a welding shop(or look online) and purchase steel spring handles that basically screw on as long as they fit over the bolt in the handle. I just like the raw look of steel vs. the chrome spring for asthetics but the end result would be the same. When my stove is really cranking in the 5-550 range these handles get warm but not to hot to touch w/o gloves.
I would not replace with the "drop away" handles found at many suppliers. At least not the ones that are porcelean. Why the are called drop away must refer to the fact then when you drop them, you throw them away because they break.
Thanks for all the good advise. I think I'll try gluing it back together for now and at the end of the season have a local craftsman I know fabricate some more durable and decorative iron replacements. Thanks for the pictures they inspired me!
