Resolute 1/2 front door gasket size and length
rwh63
500
MA
can't seem to track down a spec sheet for all the gaskets used on these stoves. in particular, looking for the drop down door gasket probably a 5/16 but not sure.
Yes, 5/16" is correct. Woodman's sells the Meeco replacement kit with a 6' length of 5/16" rope gasket. Midwest Hearth is another good source. Here is what they list for the Resolute I & 2:
RESOLUTE I & II 00042 & 00043 (Single Drop Down Door)
120-3588 1-00-1203588 5/16" Medium Density 6ND Fiberglass Gasket 5' Door
120-3668 1-00-1203668 5/16" Gasket Wire Fiberglass with Core 3.3' Griddle
30000776 1-00-30000776 3/4" Flat Fiberglass Glass Gasket Black 5' Glass
120-3560 1-00-1203560 1/4" Fiberglass Gasket 3' Flue Collar
thx. just located that thread. might have some kicking around. just for the door. didn't want to use the wrong size. gonna bookmark and print that list!
Note that gaskets come in different densities. A low density gasket in this case may not seal well. Same for a very high density gasket.
