Craig is looking for feedback on how to apply rigid foam insulation in the basement.
If I understand correctly, if we were finishing the basement now, there would need to be a one inch air space between the framing and the wall. However, if we were simply to put the insulation up and apply it directly to the walls, could we frame it and put up additional insulation in between the studs when we finish the basement later?
Thanks,
~Cath
Thanks,
~Cath
roove.htm)
broken link removed to http://www.insulation4less.com/tech_foil.asp). This adds a new dimension to all these projects. Always keep in mind that basement walls must be able to breath. Heat out in the winter and heat in the summer.
