My Attack has the above controller, it's a bit different than the other 2001's in that it has an exhaust temperature probe (and seperate knob for this function) for conbustion fan shutdown at end of burn. Anyhow, I have gone through the settings again and again..... When the boiler temp reaches the setpoint (192F), the fan shuts off (idle mode) and sometimes.....the controller turns off the circulator as well, the pump light on the controller is off too, if I push the stop button the circulator will come back on and cool the boiler to below the setpoint and all will be normal. This only happens on the rare occation, but it is totally counter-productive, as when the boiler is "overheating" it turns off the pump so it heats up more, well you get the point. I rarely go into idle mode, just the occational up-to-temp storage (slab) or power blip that resets the injection control and it has to ramp up again allowing the boiler to heat up in the 4 or 5 min.
There are three settings in the "Pr" 0. automatic
1. the pump work depends on room temp (Not this one for sure)
2. the pump work depends on controller work mode
I guess I'm fuzzy on what exactly the "controller work mode" is: ie. idle; burning; no-fire or something like that? What would be the difference in settings 0 and 2? Any other info on what you've found on the RK and it's roughly translated handbook as well. Overall I'd have to say I have been impressed with this controller, as it's settengs are easy to change, seemingly appropriate, and this one has the bigger capacitor so it shouldn't freak out as the older ones did.
Thanks for the help gang!
TS
TS
next year, with storage and all my wood for the season consistently below that 20% level,
life will be good.
