I'm working out some rules of thumb from my woodstock progress hybrid. I spent ~30 years with a smoke dragon, and I need to get the hang of the multiple damper bypass setup. The stove is connected to a insulated steel chimney that goes straight up the inside of the house with about 25 feet between firebox and top
My big "worry" is over firing the stove.. and so far I've never even got close ( judging by the surface thermometers) I have a surface thermometer on both the stovepipe and the wood stove top.
First rule of thumb.. wait until the temperature on the stove pipe moves from the black to the white area ( I think it is 350 F) before closing the bypass damper to engage the cat ( usually takes about 30 minutes from a cold start)
Second rule of thumb.. if after engaging the cat, you see/smell smoke coming out the chimney outside, disengage the cat and let the fire burn hotter for a while
Third rule of thumb.. no matter if cat engaged .. if the little metal screen above the fire box starts to glow red.. turn down the main air damper
I wonder what others use as their clues ?
The smoke out the chimney was a big clue to me that the cat was not working.. best guess ..it just was not cold enough outside to draw enough air through the cat.. could be wrong here
I'm not sure if it's OK for that metal screen to glow red, so I avoid it. If it's ok let me know
