Rust?
mikespirito
46
Coventry RI
I just got my stove last week. I used it a for probably 30 hours so far. I was opening the side panel to open the front glass when I saw this. Could this be rust?(broken image removed)
Looks like rust to me. If the paint wasn't applied well, or the surface properly cleaned prior to painting it doesn't take a lot of moisture or time for metal to rust.
Thanks. I only have had the stove for a week
No problem. Just read your other post. If paint is coming off when you are wiping down the stove with windex, and you have rust already there was an issue with the painting process. Could be any number of variables, dirty metal, temperature of the stove when painted, humidity, contaminated paint, etc.
I don't know if your warranty indicates anything regarding the finish, but it might be worth checking out.
That stinks, but don't fret over it too much. Easy fix.
