Ok, so I posted a question in the "Carbon Monoxide Emergencies related to wood fired appliances" thread, but maybe it deserves its own thread since that one was directed primarily to awareness.
Admittedly (shamefully), this isn't something that had crossed my mind before, and now it has me a bit concerned. I do plan to get and install a couple alarms this evening, but I'm not sure alarms are enough.
While CO alarms are intended to notify you when a danger is present, what are the preventative measures against rising CO levels in early morning hours after an overnight burn? Do you all simply not attempt overnight burns and make sure the fire is completely out before turning in? Or do you all wake up periodically throughout the night to manage reloads?
I'm very curious as to how the community here mitigates this risk as it is one that I haven't considered before.
Thanks in advance
Thanks in advance
My first couple over nights had me sleeping/napping on the couch.. But now.. pffft. The stove is no more likely to do something crazy at night as day.. and I burn well seasoned wood, clean my chimney regularly, and as stated have a safe and proper instal. No worries. If an alarm ever goes off, I will deal with it then. We have 2 cO monitors, 1 on each floor. One is battery, one is plugged in w/ battery back up. One has a digital readout, has never shown anything over "0"..
See now you're talking technical which is my language! Unfortuanately, my knowledge of the heat pump stops at the power supply. By the way, what I've been calling a furnace is what I refer to as the heat side of my A/C, which is indeed a heat pump. But, from your explaination begreen, my principle concern of drawing poisonous gases in the house from my stove due to my heat pump kicking on in the morning is an unlikely event?
