.I paint for a living so I have spray guns. It can be had in spray cans also
There are clips that hold the stove into the frame on each side in the front. Did you unclip them?Hello bogieb and Don2222,
That's the same blasting gun I have. I can't get the mounting shell and the stove separated due to rust any Ideas? Thanks Jeff
Yes it's just rusted really good might need a lot of oil? whats under there rollers? Or does it just slide on a rail? Thanks JeffThere are clips that hold the stove into the frame on each side in the front. Did you unclip them?
I was thinking about make a post but it fits in here.
1. Why/how does the stove start collecting rust? I have a harman p52i insert and noticed few rust spots forming (not alot but its creeping up).
2. How do you stop the rust? Do I spray WD40 on on my stove in the summer time?
rust starts when you shut them down for the season. spring, Summer have more humidity in the air and the stove is not in use and mostly forgotten till heating season starts again. I always shut the stove down clean the hell out of it and then i use my test cord and run the exhaust fan while spray fogging oil inside the fire box. shut door and on with the honey do or else list. I usually take the stove out in the shop when they start looking bad and tear apart and refurbish including Paint.
Thanks Bob I never give up on stuff!! I will sandblast the slide rail kit (should I paint the slide rail kit after blasting?) Then get the stove all back together and up and running. I will post pics as i go along. Also what the difference between the I52 and the Accenrtra. For a top of the line stove they seam to have a lot of problems lol . Thanks JeffFor Worble-The old Accentra insert is not a heat monster.The 52i is.However,there are thousands of them out there,still up and running.I thought you would give up on your project,after you found the rust,bad control board,and bad motor.So,food for thought,the slide rails kit is still available,is over 300 dollars,but maybe you can salvage yours.From your pictures,as rusty as the outer housing/slide in cage is,I would call a dealer,and see if it is still avalible,the cost difference may make it worth your time and energy.Also,if your project goes through,there is a Harman air bypass kit,mostly for the gummy stove syndrome,you will want to install the kit before you use the stove.Best of luck,Bob.
Montecarlossfan that paint job looks great I will go with satin black by stove bright alsoJust for motivation...I purchased a 52i for a steal last October,sat in the guy’s garage all summer and rusted quite a bit as you can see..but finished product ...looks amazing and heats just as well
Stove bright satin black..on the frame I used rustoleum bbq paint which has a rust preventative in it
. Thanks JeffBob,I am impressed,the rust is not that thick,but the steel is.Remember,when blasting,sand,glass or shells,scrub well with water and scotch brite pad,primer,and paint.
LOL.All steel,unrusted,that looks like steel to you,was coated from the factory.Usually a light coating of galvanized.In your area,after blasting,will rust/corrode very fast.Primer and paint are a must.If you are rich,have everything powder coated,but,the cost of that has come way down over the years.As far as the instructions on the air kit,I may have them downstairs in my parts box,or,my Harman Technician friend can send them to me.Very simple,works well.Not gonna go downstairs tonight,so will be later.Bob,
You really want me to paint it after all that hard work? J/K lol So I live in the bay area of calif we really dont get alot of cold weather. Also my house is 1424 Sq feet. I think the stove will heat it just fine
Hey bob Do you have any really good pics of the Harman air bypass kit?? Thanks Jeff
I will paint itLOL.All steel,unrusted,that looks like steel to you,was coated from the factory.Usually a light coating of galvanized.In your area,after blasting,will rust/corrode very fast.Primer and paint are a must.If you are rich,have everything powder coated,but,the cost of that has come way down over the years.As far as the instructions on the air kit,I may have them downstairs in my parts box,or,my Harman Technician friend can send them to me.Very simple,works well.Not gonna go downstairs tonight,so will be later.
I was thinking of powder coating it only if I could find 2 old house ovens on craigslist I would powder coat that baby right up heheWe use essential cookies to make this site work, and optional cookies to enhance your experience.
