I have a Quadra Fire Santa Fe stove that is in its 7th year now. Late in the last heating season the pellet feed auger started tripping the reset button, but, of course, forgot about it and now that I'm starting to heat again the problem is still there.
When I turn the stove on, auger will feed pellets for a few seconds or a minute, then trip the reset. Reset it and it'll go for a minute or 3 and a fire will light but not get to full flame. After 2 or 3 or 4 attempts, it'll finally settle in and work normally for several cycles and maintain thermostat temp setting. After the stove gets cold, start the game all over again.
I removed the motor and reduction gear, dribbled a bit of 10 weight non-detergent turbine oil into the motor bearings, got some grease into the opening for the drive gear, then, after much cussing, got the motor snapped back into place and held solidly in position - I wanted to make sure it wasn't tilting and binding. Finally had to make little shims to hold those miserable snap clip ends in place.
I have decades of experience in appliance repair but this one has me stumped. Any ideas ?? Bad reset ?? Thanks Lars.
