A couple or 3 weeks ago, several tried to help me with a problem with my 11 year old Quadra Fire Santa Fe. It wasn't feeding pellets and I finally traced it to a bad control module. I had a spare on hand, so installed it and the stove ran fine for 1½ days, then quit again. Several factors seemed to be a little off but nothing stood out as being a definite problem.....and I finally bit the bullet and agreed the new control module was the problem. I ordered a new one last week and it came in yesterday, so today I carefully read the instructions, installed the new ground, set the module at 6 clicks and installed it - with power cord unplugged.
The #2 snap disk is closing but ohmmeter readings don't show a true closed circuit - shows a varying resistance that seems to average around 68 ohms, so I jumpered it. ( I do have a spare and will install it tomorrow ) The vacuum switch does close but seems to be slow sometimes, so I jumpered it as well. Then I plugged it in, the red light came on and the blue light blinked 7 times - as it should. It felt like the pellet feed auger motor was vibrating, but I wasn't getting any pellets to the firebox. Stripped gear in the motor assembly ?? OK, I pulled the entire auger assembly out and put it on the bench. Connecting the wires directly to a 120vac source ( actually measured 122vac ) showed the motor to be running fine, so I re-installed it.
This time when I plugged the stove in, the auger did run and I got a few pellets into the firebox, but not enuf to start a fire. I thought that was probably due to the auger feed tube being depleted of pellets when removing the auger, so ran it thru several cycles to get pellets moving again.....and after 3 or 4 tries, it completely stopped again. No pellet feed. Igniter was glowing red hot, combustion air blower running full speed and right back to square one - no auger. You know, I'm absolutely disgusted and walked away before I damaged something.
I consider my self to be quite knowledgeable on this kind of thing - I owned and operated a restaurant service business for years before I retired, but this has me going. Any ideas of what I should check ?? How can I be certain this module hasn't gone bad, too ?? If it has, what could be killing them ?? - this is the 3rd in a row. At $200 a whack, this is getting expensive, but everything else checks OK. I dunno - with the current freezing night time temps, the propane furnace is barely keeping up, but at least it's some heat and the house is liveable. I'd much rather be using my pellet stove.
![[Hearth.com] Santa Fe Yet Again [Hearth.com] Santa Fe Yet Again](https://www.hearth.com/talk/data/attachments/268/268584-363267034a2fd5083667af2f1b5cd7f7.jpg?hash=vx6xRWEdsS)
