I've had all three....still got the 562 and 576. For average size firewood ....the 562 is hard to beat.. Your back will thank you later..
If your just cutting your own firewood a 562 would be perfect even with a 24" baHey guys looking for advice and suggestions from members that have experience with the posted saws. I'm looking for a saw that will pull a 20 to 24" bar routine with extra left over for bigger bar options.
The 562 has the highest power to weight ratio ever recorded in a production saw over a pound less than a 372 and still has
4.8 hp only a half horse less than the 372.If your primary wood is over 20" then bring in a 72
Husky plays the numbers game all the time a 372 weighs just under 14 lbs at 5.3 hp a 562 weighs 12.57 lbs at 4.8 specs are a little off the 2013 specs are about as true as you can get hp for the 562 is now listed at 4.7 instead of 4.8 in 2013 Believe me this saw has gained hp since 2013 they have said at Dealer meetings since 2011 the 550 & 562 have the highest power to weight ratio of Any Husqvarna saws . Don't get me wrong the 372 is still one of my Favorites.Where did you come up with that? Husky specs the 372 with a better p/w ratio than the 562.
Tlandrum is top notch. Thats where my ported saw came from.
Oregon semi chisel is DPX it seems to cut the same or faster than a LGX if that helps.What is the Oregon code for the chain you use? I love the LGX, but may be willing to try something else provided my cutting speed doesn't suffer.
I think the H codes are universal across all chains, but not 100% positive. They're listed on the actual drive tooth itself, where it would meet the sprocket. I know at least when I called Bailey's asking what the hell was stock on my 562 (because I could tell it was a safety chain just by looking at it) they asked me to look at the two and compare the numbers there.
