Hey folks, I have a scenario for you. I know you can help. I am still working away at our new home. It is totally off grid - all solar electric power and a big forklift battery.
Here is what I want to do. The topic is water heating. In the winter, I planned on originally running a loop through my boiler storage tank since that tank should always be hot in the winter. This is all fine and dandy. However, my solar array has been putting out way more power than I need, so after the battery is full in the morning - the charge goes into float mode and the panels shut down. So I could be making a ton of extra kilowatts if I had my relay set up to trigger an "opportunity load" that activates when the house has it's electrical loads satisfied and the battery is full.
What I want to do it put a heat pump water heater (such as the Accelera 300 http://www.stiebel-eltron-usa.com/accelera.html - or similar) to heat my water in heat pump mode only - and only when there is surplus energy. I think I can handle all this.
But what I am having trouble wrapping my brain around is what order to put things in. First pump my water through the heat pump water heater, then through the boiler storage tank loop (it may or may not be hot at this point, depending if there was excess energy from the sun) then pump it through a combi propane boiler designed to heat the entire house (as backup) and also designed to do DHW. The reason for the propane unit is so my primary heat for the house is propane (insurance purposes) and, if it is cloudy for a few days in the summer (when the wood boiler isn't fired) then the propane boiler will measure the incoming temp of the DHW and then top it up if need be. Ideally the propane boiler will never fire up for DHW, but it will if need be.
Does all of this make sense? I have yet to move into this new house, but my design will handle 25-30 Kwhr per day, and I only expect to use 10 kwhr. Also, if surplus energy is available, would it be possible to have the heat pump water heater contribute to the whole home heating by circulating through the 1000 gallon storage tank? Unpressurized storage.
I am really anticipating your responses! Thanks!
-Rudi
-Rudi
