Seal Gas Fireplace Insert to uneven wall
jonboy834
2
Vancouver, Canada
Recently installed Valor G3 Nat Gas Insert into existing hearth (replaced 25 yr old Valor 470MN). The fireplace wall is in natural stone - very uneven - so G3 has gaps between trim/unit and stonework - up to 1.5 ". Result is that a great deal of heat from the Valor unit escapes upward to the wood mantelshelf, which gets very hot. (Cannot touch it!) Problem could be solved with horizontal strip of some heat-resistant ceramic-wool board say 1/2" thick across the top of Valor trim suround to seal the gap . .. Any comments/suggestions?
Seal Gas Fireplace Insert to uneven wall Seal Gas Fireplace Insert to uneven wall Seal Gas Fireplace Insert to uneven wall Seal Gas Fireplace Insert to uneven wall
One option would be to trace the outline using an old-style school compass,
the kind with a pencil in it, onto a piece of carboard. Cut along the outline
with scissors, & the trace the pattern onto a piece of sheet metal.
Cut that outline out & adhere the sheet metal to the existing return on the shroud.
Probably more labor intensive than you want to get, but if you're careful, it'll look good.
Another way is to take the flat fiberglass insulation that is used for sealing fire place doors,
It comes in different widths & thicknesses & can be painted black with high heat paint.
It will look good from across the room but maybe not so much up close.
Good option. Not familiar with Fiberglass for fireplace doors. Could you provide URL for this? I also considered heat-resistant ceramic panel (McMaster Carr?) but overkill (resists 2000F+) and I could not locate any around here.
Something like this:
