Hi all,
I have been searching around this site and have found a lot of good information but I wanted to see if I could get it all in one place instead of through many different articles. I live in south eastern PA where we have about 4 months of heat needed and temps in the teens and 20's are not uncommon. My home is a ranch with a finished basement. I have about 1100 sf on the first floor with a somewhat open concept aside from a hallway to the bedrooms and about 850 of finished basement. Basement and first floor have insulated walls and the ceiling of my first floor has about an R-19+/-. I have installed all new windows and doors which are spray foamed in. I have been trying to decide how best to get away from the oil heat and being on 2.5 acres its not likely I will see natural gas any time soon and propane is too expensive. I have been going back and forth between wood and coal but there are so many options. Wood or coal boiler tied into my existing hot water baseboard system, wood or coal stove in the basement, wood or coal stove on the first floor. I ultimately want a heat source upstairs in my living room that will hopefully do the entire upstairs, possibly an insert with power take-off piped into bedrooms? but then I think I will need a second stove in the basement. I'm not opposed to 2 different heat sources either such as one wood and one coal. I should note that I will be adding a second story in the future so if the insert upstairs is a little big that's ok. I plan to build something like this around the insert on the first floor. Also how many cords of wood do you expect I will go through in a season with planning to burn as a primary heat source. Sorry for the long post I just wanted to thoroughly explain what I am deciding between.
