Hello again! I was looking for some expertise again from you all. I recently replaced my Quadrafire contour that's been out of commission for 2 years with the Pelpro pp130. I've been blown away by it's performance compared to the warn out lemon Quadrafire I bought ignorantly (lots of issues not mentioned by seller). The pp130 is installed in my unheated 3 car garage that my master bedroom is above. Rest of the house is 2 living floors and a basement, roughly 3000 square foot. The Pelpro one a 25-35 degree day is burning around 2.5 to over 3 bags in 24 hours, but it is keeping the entire house (minus basement) at 68 degrees without the furnace![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
I am refurbishing the 2001 QuadraFire Contour and looking to use it as well. One stove is going into the basement, the other will be in the same garage spot. What I would like to know is, does anyone strongly recommend which location which stove should be in? The Contour has a 40lb hopper, pp130 is 130lb hopper. Contour has a standalone thermostat or can be ran on low, med, high. Pp130 is just a dial control low, 1-10, high.
The pp130 is mainting temp throughout the house, but is working extremely hard and using 3 fans to distribute the heat. As the outside temp drops l, the difference between garage temp and rest of the house increase (81 in garage and 68 main floor last night) I was going to put the Quadrafire in the basement, but now I am thinking the pp130 may be the better choice as it may be more effective in the basement vs the garage.
Thanks all!
Thanks all!
