This was the end of my second full year of burning. Having much better wood, I had NO brown stains on my glass--hurray! Fires started right up without a lot of coaxing, too.
Since it was a cooler season than last time, It seemed to take a lot more wood to warm the place up. I noticed about half way through that the door gasket was no longer tight (failed dollar test), so made a note to get that changed when I called the sweeps. Near the end of the burning season, I noticed a "clack" sound when I closed the door, and discovered the glass was loose on one corner, and that gasket was getting tatty, too.
I called the stove & chimney guys, they ordered new gaskets. When the guy came out, he found the chimney extremely dirty, but loose at least. Changed gaskets (promptly broke the glass
Why did the firebox and glass stay immaculate while the chimney got filthy? Is it normal? Did the loose glass and other seal have anything to do with it? Also, I suggested changing the baffle gasket, since the other two had worn out, but they said it usually stays intact much longer, and that they would have to pull the insert to inspect it. What do you think?
). Why did the firebox and glass stay immaculate while the chimney got filthy? Is it normal? Did the loose glass and other seal have anything to do with it? Also, I suggested changing the baffle gasket, since the other two had worn out, but they said it usually stays intact much longer, and that they would have to pull the insert to inspect it. What do you think?
