Hi All - Long time lurker, first time poster, so please be gentle......
I am in the UK with a 5kw multi-fuel (coal and wood) DEFRA approved stove. I have secondary burn (referred to as clean burn in the manual). Much to my wife's annoyance, I have started trying to measure and monitor the temps actually inside the box (as opposed to the flue temps which I measure using a magnetic thermometer).
My query is, what temps do most people need in the box to bet the secondary burn to work most effectively? I am really just looking to see if I am optimising the efficiency as best as I can or if I am sending too much heat up the chimney. This is my first winter with the stove since it got installed so trying to get all the mistakes made this year!
Apologies if this is covered elsewhere, I did a search but found nought.
/ 180
. You could start very gradually dailing down the primary air intake around that point.. Or let the stove get up just a few more degrees, but not too much till you get to know how fast she heats up. I take the primary air intake down about 1/4 at a time, with few minutes in between. As you turn down the primary air, the secondary flames should show even more. It's kind of the dance between 'less primary air = more secondary flames' at this point and that's the trick really. Once those secondaries start rolling the stove top temps should continue to rise, cos the secondaries heat the stove more, rather than sending too much of your heat up the flue - and that, as you say, is what you want. Keeping the primary open for too long will send too much of your heat up the flue, but turning it down too soon will smoulder the wood before it's had a chance to take well enough, then you get a "un-clean burn"!
