Hi all, I'd greatly appreciate any feedback that you can provide.
I have a single brick chimney with two clay flue liners inside of it. One clay liner terminates at the first floor, the other liner terminates at the second floor. The problem is that these two flue liners do not have any separation between them. Currently, they touch. My state's (Massachusetts) building code says:
I plan on removing at least one of the clay liners because it's quite badly damaged, and replace it with a stainless steel liner, but that doesn't solve the flue separation. There is physically enough room inside the chimney to shift one of the liners over a few inches and have a masonry wythe between them. However, there is not enough room for the human required to do that. What I mean is that the chimney is fairly tall, and the space is too narrow for a person to squeeze into the chimney to build the masonry separation.
I can't think of a way to build a brick separator without punching many holes in the chimney, which I'd very much like to avoid. Is there a way to meet code that doesn't require building a brick separator? Like something I can drop in or pour in from the roof? Or is there some sort of janky reacher-grabber tool that would let me build up the masonry wall while standing on the roof? Or are there flue liners that don't require masonry separation, even when the code calls for it?
Any suggestions here would be very much appreciated. I don't want to just cover up the issue, but I also want to fix it myself if at all possible.
6001.10 Multiple Flues: When two or more flues are located in the same chimney, masonry wythes shall be built between adjacent flue linings. The masonry wythes shall be at least four inches (602 mm) thick and bonded into the walls of the chimney.
