I've been waffling around unsuccessfully for years, finally broke down and bought it. Some learning curve, and slow. But, went from sawdust to long curls on the first try. GREAT PRODUCT!
Have a close look at the chain after you have it sharp with the file an joint.Notice the angles on the cutting edges and how deep the gullet is.Then try to duplicate it by hand.I think the file n joint is awesome. I used the one page instructions and had it rocking in no time. I sharpened a chain that I had touched up by hand probably 10 times and i couldn't believe how well the granberg did. The one issue is the sliding shaft and bushings so I am going to "upgrade" the bushings and maybe swap out the shaft to reduce binding and friction. I will post an update when done.
And don't forget the rakers i don't think the file and joint addresses them
I can't tell you how nice the Stihl (Pferd) 2 in 1 file is for my needs, and hits the rakers all at the same time. I've never used anything better, and it's fast.
I eagerly await your post! I love it when creative, ambitious types like yourself make incremental improvements on already good products. Maybe you can sell an aftermarket kit once you figure it out...I think the file n joint is awesome. I used the one page instructions and had it rocking in no time. I sharpened a chain that I had touched up by hand probably 10 times and i couldn't believe how well the granberg did. The one issue is the sliding shaft and bushings so I am going to "upgrade" the bushings and maybe swap out the shaft to reduce binding and friction. I will post an update when done.
I got some diamond bits last year for my dremel-tool, but was doubtful that I could get the angles right. I'll eventually figure out how to set it up so I can keep the angles consistent. I was not even close with the freehand filing. I do believe that will be a better, faster setup compared to the file-n-joint, but I might as well do it in the dark with how well I do it freehand!I bought one based on everyones reviews. Tried it one time and went back to my Dremel with a diamond bit. For me its an easy choice for the Dremel with a good diamond bit.
Today I used one of my chains I sharpened with the Grandberg, it was a Stihl semi-chisel. I have never had a chain come back from a dealer sharpening cut as well as this did. Its a great investment in my opinion!
Yeah buddy! That thing is awesome!
