Should a catalyst get red hot?
Yes, it can. It's fine as long as it stays under 1500ºF.
Reactions: Teachme
I sure hope so or mines in big trouble!
Summary:
Should: no.
Can: yes.
Wow, thats hot!! Glad to hear its safe.
You want it hot, if it is used not only to clean up the exhaust but also to provide the majority of the heat (when running at low output).
My stove running low has a firebox full of black wood in it, and you have to squint to see some glowing (it is there) and a large part of the heat is provided by the glowing brick (cat)on top.
It is fine for it to glow, you just want to make sure it doesn't overheat.
BK did a couple good video on how a Cat works:
