Should I insulate my liner?
arnermd
630
Tolland, CT
Hello All,
Looking for some advice to reduce buildup in my liner. I burn 4 cord a year and typically remove 3-5 gal of shiny black crumbs per year after cleaning. Seems excessive to me and wondering if it would be of benefit to insulate the liner, at least the top 2-3 ft or so where the majority of the buildup seems to be. See my installation details below. I typically do not have any draft issues, even with a cold stove on a warm day. I typically measure 0.1 - .18 iwc with a hot flue.
The current liner is 8" uninsulated, corrugated, single wall stainless inside a masonry flue. My VC manual gives the option for 6 or 8" flue but requires
8" to run with the front doors open which I occasionally do.
I have been running this stove for 13 seasons now and the amount of build up has been pretty consistent. I have been getting just under 2 seasons out of my cats and nearly always burn with the cat temps >800, usually over 1000-1200 with full fuel load and occasionally over 1500F when things get out of hand.....
Any suggestions would be appreciated.
[Hearth.com] Should I insulate my liner? [Hearth.com] Should I insulate my liner? [Hearth.com] Should I insulate my liner?
Yes that is excessive. Insulation would help. How long does your wood sit stacked? Do you ever measure the moisture content?
A cat should last 10000 hours. Two years seems short.
The draft seems quite high.
Reactions: all night moe
Right... forgot to mention the wood. I let it go at least 2 years under a metal roof. All Ash and Red Oak. I do have a moisture meter, as I recall I am typically around 15% - 20% MC
A Cat should last more than 2 years, I agree.... Have you any experience with the newer Vermont castings flexburn stoves? They eat cats.... very common problem. Probably becuase they lack the ability to control cat temps....
Double-walled stove pipe connecting to an insulated liner will help keep the flue gases hotter which will reduce creosote condensation in the flue system.
It would also be helpful to know what the flue temp typically is. Creosote starts condensing below 250ºF. We typically run with about a 400-550º flue temp in a straight up, insulated flue system. After ~7 cords I get about 1-2 quarts of soot and sote, but we are in a milder temperature zone.
Fortunately I have lots of logged data from last year.
The first plot is what I would call a typical burn,
  • Flue temp is from a probe in the exhuast gas about 12" above the top of the stove.
  • Cat temp is in the gas about 1" downstream of the cat
  • Griddle temp is metal temp measured in the center of the griddle twords the back of the stove
This plot is flue temp for the entire burn season. Hard to see details here but you can see typically my flue temps are 300 - 600.
Same plot but for the Cat..... this is why I think my cats don't last. I started the season with a new metal cat from Midwest Hearth. Interesting how the mid winter spikes seem to be worse, could be I was running it harder or maybe it was increase draft from colder outside air temps.
Nice data. Yes, those spikes above 1600º are not good for the cat. It would be interesting to see the flue temperature higher up so that it shows pipe temp instead of the stove exhaust temp.
So in the first graph by 21:00 are you in coaling stage?
Edit. I’d try a damper to slow things down a bit. Maybe those mid winter spikes are when it cold and windy
A damper, and some insulation would make a big difference
That data I do not have.... but it must be quite a bit colder if I am collecting that much carbon. I woudl think the masonry woudl keep the liner warm enough but I guess not? The top 13' of the chminey is exposed to outside air on 3 sides.... maybe thats where all the heat is going?
Yes around 21:00 it was coaling.
Temp spikes: They do not correlate to wind or outside ar temp. I have been searching for the cause for 13 years. Much of my trials and tribulations are documented in the VC performance thread if you care to read them..... I warn you though it is not for the faint of heart, it is a tragedy with no happy ending.
Damper: I agree it seems like a damper would help, which is why I have run one for years, you can see it in the pic on the vertical section out of the stove bout 18" up, handle is on the left side. A couple years back I actualy made a seat for it to seal off the gaps around the circumference of the disc and blocked up all the holes in the plate. It seal pretty good now.....
Sadly it does not work as well as you think it would. I have tried running with it full open part closed and when the spikes happen they happen. It is one of the most frustrating things I have ever experienced. The one thing that I have fouind that works is completly blocking the secondary air inlet. That seems to calm things down but I suspect I am not getting 100% combustion when I do that.....
Yes definitely, though a surprising amount is lost through single-wall stove pipe too.
you mean the vertical section right off the stove? I can check the gas temp where it goes through the masonry and measure the loss, once I have a fire going....
Yes, though the largest drop will be in the exterior, uninsulated liner, a 50-100º drop is not uncommon from single-wall stove pipe. It wouldn't surprise me if the flue gas exit temp at the top of the chimney is 200º or lower.
The downside of insulating the flue system is that draft will get stronger. It sounds like you are fighting that.
Agreed, but I do not run with door open very often. Maybe an hour or two a week.
That’s fairly often. It doesn’t take long for multiple variables to really work together like wood moisture, uninsulated flue, and lots of cold air rushing in to the stove to kick the creosote formation into overdrive.
My stove is the encore 2040. I am double wall insulated 8 inch all the way up to roughly 16ft. Out the top of the stove and straight up. I run roughly 3 to 4 cords max and my wood is dry like 15% no more then 18%. last year I didn't do my mid season clean. I probably got 3 cups of a grayish/graphite looking material from my clean out.
Reactions: arnermd
I just cleaned mine. 15' by 6" single wall stainless liner. Tee'd off the back of the stove up into center chimney. Flue gets heated by the stove.
Burned ~3 cords. Primary heat during winter 24x7.
Less than 2 gallons of crud.
Last winter I did have an over fire with a full load of dry maple. I tend to not pack it full now. That was no fun at 1am.
Reactions: arnermd
Two gallons is still too much!
Much closer to 1 than 2. But understood. I'm not sure what else I can do other than installing a double walled insulated liner. Wood is dry. I do try to follow @Woodsplitter67 and other's on this site burning recommendations for the VCs. This will be my 5th year with the Encore. I had 35 years with a Noble woodstove prior to that, which was very easy to operate. Yes, I burn a lot less wood now but I need to oversee the Encore much more. And now I don't trust the stove after the over fire last winter. I'm still learning and willing to keep trying though! Especially with the helpful people here!
Reactions: arnermd
Even 1 gallon of creo fuel will make for one heck of chimney fire. I would be worried about the integrity of the liner if it all went up in flames.
I’d be doing a mid winter sweep. An Auber AT 200 thermometer alarm could help. We know the VC is temperamental. It’s a matter of when not if for the next chimney fire.
I totally disagree with the last part.. completely false
Agreed. I have the Auber AW-TMB-Deluxe wifi monitor which sent the alarm to my phone at 1am as the temps crossed 1650. Of course I touched the stove controls trying to stop it which only got it going more and eventually topped out at 1740 with the pipe glowing red. Lesson now learned from woodsplitter67, don't touch it. That black section in the pic is a section of black pipe loosely wrapped around so you don't see the stainless pipe coming down.
My old stove, high is high, low is low, off is off. With the Encore, low can go ballistic and there is no off. That's why I don't trust it.
  • [Hearth.com] Should I insulate my liner?
Do you get a gallon or two of creosote out? How many chimney fires have you had?
Your system may be better and the last statement may be false for you. Based on the facts disclosed I think another chimney fire is very likely. Best predictor of the future is the past.
