Hi, the masonry stove i have here in my old apartment i'm renting is not holding heat for long.
After the embers get cold and i close all the doors and shaft the heat on the surface of the tiles disappear quite fast. (never counted, maybe 1/2 hours)
I checked with a lighter and when it's closed there is no air pulling action....
The channeling is only the part i marked, that "roof" is empty.
I heat the stove enough to not get too hot.... i mean, as i know, there is a risk to crack the bricks if heated too much so i tend to check with my hand the upper part of the stove's wall if it's very hot (which is on the other side, not visible in the photos).
Should i stop only when all the surface of the wall is super hot?
So why is not holding heat for like at least 4/5 hours? is it because it's too small? or the bricks have been cracked from previous owner because overheating? or there is a problem of air circulating that i don't see and is taking away the heat faster than it should? Or Am I heating not enough and beeing paranoid about cracking the bricks?
Or maybe it is just bad made?
thanks in advance
