so i have not used my king for last 10 days. I turned her on today cause house got a lil chill in it. i could feel cold air blowing threw the stove when i first opended the door and bypass. cause the stove was so cold I put only a small amount of smaller peices of wood in it to get her started. The smoke just wanted to come out the door instead of going up the chimney. I closed the door and the smoke started coming out all around the gasket even tho bypass was open. Also smoke starting coming out the back and bottom, it was so much i count tell after a minute. i also noticed smoke coming out of all the joint connections of the double wall black pipe. After a couple of minute the smoke stopped and actaully started going up the bypass.
Got all my fans and blew the smoke out. Everything is ok now stove is running fine.
im assuming my gasket in no good around the door even tho my dollars test was fine. And imalso assume outside my class A chimney pipe must have a leak somewhere or their not twisted closed enough or somehow the air was just wrong timing that it was just rushing down.
ANYWAYS PROS SEND SOME ADVICE PLEASE.
![[Hearth.com] Smoke and more smoke [Hearth.com] Smoke and more smoke](https://www.hearth.com/talk/data/attachments/157/157318-1c1c293aab0dad79932fb761815170eb.jpg?hash=tQKRltEwX4)
