Smoke in my Great room. Newer home, 5 yrs old, Accucraft fireplace insert into 14" Class A, insulation packed dual wall flue pipes. 4 ft long, stacked on each other. Two sided FP doors, not leaking at the doors. Got a fire alarm today, and lots of smoke on Great room side of FP-- only up high at about 12ft near cathedral ceiling.
The flue pipes are enclosed inside a masonry sheathed 2x4 chase.
No smoke on other side of FP(bedroom) and no masonry sheathing there-- sheetrock wall above FP doors. My conclusion is that the chase enclosing the flue is building up with smoke and it finally is released at a crack in the mortar near cathedral ceiling. . .
Question: the ONLY place I can figure this could leak is at the tiny clearance area around the throat damper shaft for the flue. However, it is hard to believe that tiny exit spot could allow so much smoke out that it could be "seen" and sensed by the fire alarm. . . Hard to believe also that the dual lined FP flue could be leaking-- at their tight joints for example.
Whatever the case, The FP was really hot(door glass was over 550°F, I have a thermocouple meter and checked it). I have run the FP this hot before and not had this problem. . . At least not enough where I could "see" smoke and certainly not enough to cause the fire alarm to go off. I checked up in attic where the dual FP flue is sealed to attic floor-- it was warm but all was OK no evidence of overheating or anything.
So, wondering if you have any thoughts on this and if you agree that the clearance one the flue damper shaft is the only possible place of exit?
Appreciate any thoughts or suggestions you may offer. thanks for your time!
