Continental makes some good snows...check out the reviews on tirerack
Sent from my VS986 using Tapatalk
The little lady was in Costco the other day and stopped by the tire department to see what they had available. A random stranger who overheard the conversation offered up his opinion that snow tires were a waste, that all she needs to do is let some air out (she thinks he said to let out 8-10 psi), and the regular all-seasons will work as well. Any opinions about this?I priced it out and found that it was a wash between buying a set of four new wheels with snow radials from the tire rack dot com, and buying steel wheels and tires here and there to make a winter set.
Then I found brand new alloy take off wheels that were cheaper still on line. (take offs are when someone drives directly from the car dealer to a wheel shop to put new after market wheels on a new car)
I only got around to buying two , but with traction control and anti lock brakes it hasn't been an issue for the past three years .
I start work about the time the plows are just leaving the highway yard, and travel all over the northeast US for my job.
Your first sentence here is correct, but the sidewall numbers are simply maximum allowable, not a guide to proper inflation on YOUR vehicle. I run heavier than stock tires on my 1/2 ton truck (the factory tires were actually under-rated for vehicle capacity), and going anywhere near the listed sidewall pressure on those would have me riding on the center bead of the tire, since my truck is never loaded anywhere near the maximum allowable weight rating of that tire.be careful with using the door jam sticker for the guide of air pressure. that sticker is for the tires that the car came with. change the brand and model of the tire and the door jam sticker is out the window. proof is a few years ago ford was going by the sticker on their door jam on the explorers and people on the highway were having blow outs and rolling over the vehicle result was a long drawn out court battle to see who was at fault ford or the tire company. if you don't want to use what is on the tire ask the tire company thru email. i use a tire shop that has been in the tire biz for three generations thay put my 80 truck tires at 55 pounds result is bad fuel milage and wishy washy ride bad on corners. usually slightly less than max of what the sidewall of the tire says. my car came with tires that had a 35 pound max. the tires i have on there have a 45 pound max. using the door sticker is useless for my tires. as far as running tires at a lower pressure that makes things worse. it's like running wide tires in the snow. narrow tires make for a better grip in the snow. more pounds per square inch than wider tires.
My understandings about this is that Ford specified a tire pressure that was too low due to issues with handling and ride quality. The Firestone tires overheated because of this and suffered tread separation. More here: https://en.wikipedia.org/wiki/Firestone_and_Ford_tire_controversyproof is a few years ago ford was going by the sticker on their door jam on the explorers and people on the highway were having blow outs and rolling over the vehicle result was a long drawn out court battle to see who was at fault ford or the tire company.
that is old info developed by the military to help increase traction on ice and sand, it worked for the old bias ply tires, and is similar to what off roaders do today when they leave the pavement, but will ruin a modern radial tire quickly if you run at any speed that way.The little lady was in Costco the other day and stopped by the tire department to see what they had available. A random stranger who overheard the conversation offered up his opinion that snow tires were a waste, that all she needs to do is let some air out (she thinks he said to let out 8-10 psi), and the regular all-seasons will work as well. Any opinions about this?
i usually run them at 80 psi and get the best milage possible for the vehicle and my last 3 sets of e rated tires i got 55000 miles out of them i don't don't think that i'm doing anything wrong. i get 50000 miles out of simple 40000 mile tires.
but to each his own![]()
Buy 4. I've only had experience with a certain type... Firestone Winterforce. Put them on a girlfriends car for year round use. Broke up with her... 2 years later different girl (who ends up being my wife now) her dad put them on her Toyota Corolla for year round use... got 30K miles out of them with decent tread left, just not much of the winter tread. Bought another set and running those year round as well on same car. I then bought a set for my Ram 1500 4x4. Got them studded on some dedicated steel wheels i found on craigslist. What i like about them is the tread is not the super soft compound that wears quickly on warm or dry pavement. Studs help with ice. They are also on the cheaper end for snow tires due to them using normal compounds and not the new soft rubber compounds. Snow tires are amazing. You can have the most advanced traction control system around but if your tires cant grip it doesnt matter. Also remember it's not always about acceleration. Snow tires matter most in stopping and turning, 4wd and even antilock brakes dont help much when you need to stop in a hurry in winter conditions.
The cost difference between a cheap snow tire and a top of the line snow can be as much as $500 (for 4). However, the difference in performance between the two will also be significant, and over 5 years, that cost differential is only $100/year, probably a lot less than your deductible. It only takes one "incident" or one time getting stuck that will easily justify the better snow tire.
You can find Nokians at some upscale tire shops, and by mail at discounttiredirect.com.
That is the stupidest thing I have ever heard.The little lady was in Costco the other day and stopped by the tire department to see what they had available. A random stranger who overheard the conversation offered up his opinion that snow tires were a waste, that all she needs to do is let some air out (she thinks he said to let out 8-10 psi), and the regular all-seasons will work as well. Any opinions about this?
He was in a wheelchair, so I'm not sure that would have been the most charitable thing to do. I do appreciate your strong opinion, I like when folks don't mince words and there is no doubting what they are thinking. I'm glad I asked!That is the stupidest thing I have ever heard.
No matter what the PSI of the tire, all tires bend and deflect when the run over pavement. This deflection causes internal friction and friction causes heat. Sometimes this heat buildup is exponential with very low PSI (anyone remember the Explorer/Firestone fiasco?) and can destroy a tire (catastrophically) and cause a blow out/car flip/other deadly situation.
The best things she could have done and punch the guy in the mouth. Maybe then he wouldn't hurt someone else with horrible advice.
While said advice was a very un-informed opinion, and dead wrong, I can say you don't get around much. I've heard more stupidity than that in just the last two weeks, much of it while standing in line to vote last Tuesday.That is the stupidest thing I have ever heard.
To clarify, you're talking about tire pressures on a truck rather than a passenger car...those pressures would be inappropriate for most passenger cars...
I'm afraid this may be a silly question- I want to get snow tires this year. The car is front wheel drive. I only need to get two, for the front wheels, right? Also, any thoughts as to the best ones to get?
Do not get only two tires (snow) mixed with all season tires. Check out the youtube videos on that subject... they do comparisons
I finally bought Falken winter tires for 350. at Pep Boys and they made a huge difference over my all season tires.[/QU
changing to snow tires is going to make a big difference from any tire in the snow. all season tires are not good in snow not good in mud not good in rain. they can't make a tire that is good for all things. if you change tires every season your next tire should be a highway type. for spring summer and fall. they are quieter and do better at pumping water. so highway and summer tires should be the way to go.
