On my roughly 6th burn on a brand new Jotul Castine F400. BeGreen gave me some awesome advice on how to run it and I pushed it up to 600F this evening in a home that had been empty for several days (even drained the pipes). When this stove gets up to temperature, is starts to get that burnt paint smell.
I did the first rec'd burns at 200F, 300F and 400F for an hour each, then I burned the stove six times since then. Only two of those times did I take the stove over 500F, but it was for an extended period. I've checked thoroughly to make sure that there is no actual smoke coming out anywhere (had the stove shop install it, BTW), so I know it is the smell of the black paint.
So how long does that last? I'll probably be burning most nights onwards from this point since I doubt we'll have a low temperature higher than freezing and we're looking at a forecasted 5F for this Saturday. I'm a little nervous overall since this is a new stove and I know it takes a while to get a hang of it.
The Castine heats really differently than the old, leaky VC. The VC would get real hot, real fast and then there was close to zero probability of an overnight burn. This stove seems to take longer to warm up but makes a more "persistent" heat. The first time I banked it for an overnight burn, I left it for 10 hours and when I checked it again in the morning (slept in a bit - yay!) there were *still* enough coals for me to rake them out, throw some splits on and off it went! Couldn't believe it out of a little 1.7 CF firebox. Granted, I didn't need oodles of heat that night, but it felt good to still have coals much later. (The stories on here about the BlazeKings makes me think one can load it up, then go on a long overseas vacation and still return to a warm home)
Thanks for listening!
