Alas I had written instructions regarding reloading the stove for my wife:
1. open secondary air
2. open damper bypass
3. stir coals a little
4. reload
5. wait until stove top reaches 450-500
6. close damper bypass
7. close secondary air in 1/4 to 1/3 increments watching for the cat to take off in the rear of the stove.
She has not been stirring the coals when reloading, and she closes the damper immediately after reloading and starts closing the secondary much sooner than I do.
I went to show her the instructions outline in the book and realized it instructs to do exactly as she is doing! It instructs to not break down the coals but stir them to let ash drop through the bottom ( i almost always break down the larger chunks!). It then recommends reloading and closing the bypass immediately and even states that if the coal bed is sufficient you can within 5 minutes have the secondary air control closed down as well (i have been usually doing this over 15-20 minutes).
I always thought you wanted to char the wood a little bit and since I usually pack the stove to the griddle it takes a little longer for the top pieces to catch and char a little. I always though you would want the stove top to get back up to 450-500 as well before closing the damper.
So I am now eating some crow and taking some flak.
Anyway, I have been trying the method recommended now and It seems to be working very well. The stove top takes longer to get up to temperature but actually in the long run after 40 minutes or so the stove top has gone from 300 to 600 and stays there. The catalyst seems to be slower to take off, but once it does it really starts cranking (even better than using my previous method). We seem to be getting longer and more efficient burn times as well (maybe an extra hour but with far better heat output over the long term).
So what gives? Have i just had the wrong idea all along? I thought the general consensus was what I had been outline first....
4. reload
