Lidar and solar roof projectThey didn't give you the fish eye pics they took from the corners of your roof? (That is the only way to calculate a.solid estimate of yearly production).
I think ours minimum charge is $24 on my net metering rider then they get my bypass charge based on size of array. Storm recover Fee…. Some other fees. I’ll post next cycles full bill.Lucky you. I started with a $12.5 monthly charge for the connection and it's above $17 now...
On the other hand, having "power insurance" (i.e. I'll get power when my generation is not working) is worth $0.6 a day...
Total for the month. AC is on still. November is our no ac or heat month. I don’t think I could 100kwh. That’s 10 hours at name plate capacity.Net export of 2.5 kWh per day or total?
I had my panels installed October 1 and I was happy that I broke even in October (no mini split heating yet); generating and consuming about 10.5 kWh per day average.
Then summer came and I got about 3 times (best days 3.5 times) more generation.
If your production also gets tripled in summer you can generate 100 kWh in a day. That's massive...
(Though maybe the factor 3 will be less as your panels face south; mine benefit a lot from the sun being higher in the sky given their E/W orientation).
My morning tree cover is gone with the sun being more in the south.
But the afternoon is still very present.
This was with a clear blue sky all day.
7.2 kW split E and W facing -->19.6 kWh and change
My roof is fairly steep, 8/12 pitch so the snow typically slides off after a day or 2. If it's very cold or actively snowing, no production. December is abysmal here, I think I averaged 5 kWh/day last year.Yes, that's an issue for me too, snow.
Roof not very steep, on the second story, with a yard sloping away from the home. I need to be 45 ft away the be able to look parallel to the panels, i.e. be able to put a broom on them.
I looked at those extension snow rakes for panels, but none are long enough - and if they were I'm not sure I'd be able to handle and control them well enough...
No issue on the coast in SC tho...
I just checked, and since 2018 I have between 170 and 200 kWh in Dec., so between 5.5 and 6.5 kWh per day when averaged out.My roof is fairly steep, 8/12 pitch so the snow typically slides off after a day or 2. If it's very cold or actively snowing, no production. December is abysmal here, I think I averaged 5 kWh/day last year.
I've only had mine 2 years (well, come November). Decembers I get 165-180. In January it is 117 (for both years).I just checked, and since 2018 I have between 170 and 200 kWh in Dec., so between 5.5 and 6.5 kWh per day when averaged out.
I get 0 on a regular basis in winter. Mostly from snow cover, but at times it is so dark, that not enough volts are made to get it started. Heck, on Sept 26 of this year, they only produced 3.1 kwh because it was so dark out.I have an 8.4 kW system. mostly south facing but 7 West facing panels. Gets some shade in the afternoon. My best daily production in the summer is 57 kWh and these days it's around 25. Worst ever was Jan 7 2024 I produced 0.0 kWh due to panels being covered with snow.
I think you owe yourself an upgrade 200w and 100Ahr. Could run a fridge for a day or more.For the record I have a hobby PV system, 60 W panel, 24Ah LFP battery, lots of shade. Originally set up in 2007, battery since updated.
My new controller tracks production, I am on track to make 20 kWh in 12 calendar months. But I think the LEDs on the controller eat into that a bit.![]()
Here is the first all solar electric bill. I used 41 kWh and after all the minimum charges and credits I have a $14 bill credit.
Since Tesla only goes by calendar month and my bill cycle does not I don’t have an easy way to tell my household usage. I’m happy so far.
The battery credit is the only reason. $35 of charges even if I used zero power. i thought I might have a negative net usage but I charged the car 80kwh.It's a great feeling when you open the "bill" to see you owe nothing!
