Well, I'm trying to build a permanent type ground mount in my head. I started with treated lumber but changed my mind and decided to go with galvanized pipe. I'm putting the structure down a dead south facing hill. Two rows of 13 panels. So 45' x 10.5'.
I concrete in some 2 to 3 inch wide vertical pipe (say 3' below and 3' above ground). Two verticals, one towards the top of hill and one in middle of hill.
I do this 11 times - 22 vertical pipes, 4 feet apart. Now I connect the top of the hill pipe to the lower hill pipe with horizontal pipe. I drill holes between vertical and horizontal pipe and bolt them together. Now I run super struts (from Lowes) across this structure - like 4 or 5 horizontal runs. How to connect the super strut to the pipe?
One idea, I drill large enough holes in the pipe so the head of the bolt fits through the hole. Next I make a narrow hole so I can slide the bolt (like a key hole). Now I can bolt the super struts to the pipe. Next, I attach the panels to the struts. Main cost about 18 ten foot super struts, and panel connector pieces. Seems like it should work.
