So I bought a house which has an exterior masonry (cinder block) chimney. On the inside there appears to be a thimble running through sheetrock, but when I pulled the cover off this is what I found and I'm not sure what I'm looking at.
It appears to be a short length of 6" pipe on the inside with a couple screws holding it to a T inside the chimney, and 8 inch pipe on the outside. Idk if it's some sort of thimble that got cut or someone's attempt to make their own double wall pipe.
Now what do I do? Do I need to cut a gigantic hole in my wall to rip this thing out? What would i need to replace it with? Can I make this work somehow?
From what I understand I need double wall stovepipe connected to this thing because the vertical run of pipe will be less than 18" from the wall.
![[Hearth.com] Someone cut my thimble? Now what? [Hearth.com] Someone cut my thimble? Now what?](https://www.hearth.com/talk/data/attachments/319/319705-7a8f7c73c4f9063bb93961291a8d6b70.jpg?hash=PLMMVLRUpx)
![[Hearth.com] Someone cut my thimble? Now what? [Hearth.com] Someone cut my thimble? Now what?](https://www.hearth.com/talk/data/attachments/319/319769-988a2e8662e1e70608a75ed00b47244f.jpg?hash=YXyIyYclLR)
![[Hearth.com] Someone cut my thimble? Now what? [Hearth.com] Someone cut my thimble? Now what?](https://www.hearth.com/talk/data/attachments/319/319770-6a5556f458a84eebaf639a2ad79f252f.jpg?hash=2iCoSRwTI8)
