I just wanted to get some feedback from anyone who owns a Sooteater.  I just bought one and mostly am wondering how tight of turns folks have successfully taken with it.  I ordered the SLK-24 Model which is the one for chimney liners even thought I am going through class A pipe.  The reason I did this is because it looks like this model boasts an even higher degree of flexibility than the open chimney version.
I have always cleaned our set up from top down with a flexible rod and poly brush kit and had good success. The challenge is, as you can see from my profile picture, our set up has two 45 pieces directly exiting the stove outlet and then goes into straight pipe. I did this to space the larger stove further from the wall. I would like to ensure these two 45’s remain as clean as possible too and my pre-existing rod set won’t quite make it all the way through.
I would like to get feedback and see if I could go from the bottom up, through the top of my stove, up into those two 45’s. It would be a pretty good bend initially to get the rod down through the stove top opening and then immediately upward again into the pipe.
Thoughts? Worst case, I can always go top down like I have in the past but am trying to avoid having to couple and decouple all those rod sections while they hang down into the chimney and could possibly fall.
		![[Hearth.com] Sooteater Feedback [Hearth.com] Sooteater Feedback](https://www.hearth.com/talk/data/attachments/262/262149-6074cd430fb03a8c3faa71cfb7d9c564.jpg?hash=ypreLsBalw)
