First post...
First, I know most of you are most likely tired of answering what may be the same ol questions for newbs. I have been searching here but just get confused and a little overwhelmed with all the additions and new ideas bouncing around. Is below too simple to work, and if it works am I just doing it wrong?
Thanks VERY much in advance.
My mom's old house had an older Tarm in it and she gave it to me. Now I need to hook it up obviously and have been racking my brain trying to figure it out.
Background.
My house is a 1790 30x40 cape. Insulated, but there is only so much one can do with a house that has been restored as close to original as possible. So, the house is warm, but in no way modern efficient. I kept it warm with 90% heat coming from my very old Home Heater wood stove, but at times it was chilly. My water is still oil heat so had to use oil to get that.
My heat and domestic hot water is relatively new, Buderus G215 Boiler with a Buderus ST150/1 indirect water heater attached (see photos) . It's a water to forced air system with two separate exchangers, one up and one down.
OK, I have set up the Tarm in a room on the first floor for now as I have no outside access to my basement to get wood down there I don't have the time or money to put it where I want it at this point (in it's own outbuilding maybe) and I also wanted to see if it worked OK this season before I dumped money into doing so. So as it is now, this is a somewhat temporary setup to get me through the cold northeast CT winter with little to NO oil.
Below are two very rough sketches. First is how the furnace is set up now, and the second is what I am thinking would work in adding the Tarm. Other photos are of my existing system.
W = domestic hot water
F = Oil Boiler
H = Water to air heat exchangers.
Thoughts??
Thanks
Greg V
(broken image removed)
Background.
F = Oil Boiler
Thoughts??
Thanks
Greg V
