Help! Without any warning, sparks came out from the (air intake?) gap that's between the vertical wall above the door and the flat mantle, and very noticeable smell of smoke filled the living room!
This happened after I had shuffled the logs and closed the door - luckily I was there to make sure nothing worse happened. Once I turned off the fan, the sparks stopped. The insert (Pacific Energy Super LE) burning fine* the whole week (but see below) - What do I need to do??
*of course, need to add some background on the likely culprit:
I cleaned the chimney from the top recently (with SootEater), and even replaced the gasket on the baffle. During a chimney clean a couple of years ago I had made the mistake of not plugging the air intake tube with a rag (https://www.hearth.com/talk/threads/flue-hygiene-airflow-newbie.191795/post-2577085) but luckily vacuumed out the soot from the tube afterwards, per advice by @begreen. This time I didn't forget the rag, but enough of it stuck out of the tube and got caught by the rotating brush and pulled out - which I didn't find out until I was done with the cleaning. So, tube filled with soot again.
Again, I used the same method of vacuuming it out (stiff piece of garden hose ductaped to vaccum). While the initial performance of the insert definitely seemed a bit impaired (reluctant secondary flames, etc.), after a few days things returned to normal - until now!
I'm assuming there's some more stuff caught in the EBT that I could not reach with my vacuum ...and maybe it finally shifted somewhere else to start causing problems? Is my only (or best) solution to pull out the EBT? (is there a good instruction thread on that?) Is there any other explanation, e.g. something to do with the baffle/gasket?
Thanks for all your advice!!
