Braeburn Thermostat operation and setup.
I have a St. Croix Ashby-P Insert. The thermostat is hardwired. It is level and I can’t seem to get a temperature setting that I am looking for. It seems that the low temp setting of 70* to call for heat doesn’t want to come on. When it does come on, it will continue to run the stove for a +5* temperature rise. If it comes on at 70* the call for heat will shut off at 75* is this normal? I have included two photos, one of the face plate and the other showing the inside.
With the faceplate off, there is a longer cycle duration setting. What does this do? I can’t seem to move it in any direction. If this can be moved, Will this lower the duration run time and drop the temperature rise before ending the call for heat?
The stove manual states 5VDC for the thermostat, can a standard digital thermostat be used for a more accuracy setting?
Steve
Pheasant Hollow Farm
![[Hearth.com] St. Croix Ashby-P Insert & Braeburn Thermostat operation and setup. [Hearth.com] St. Croix Ashby-P Insert & Braeburn Thermostat operation and setup.](https://www.hearth.com/talk/data/attachments/140/140723-95fd8e0fb2bd61652d1d6ac110dcd4ea.jpg?hash=H0DL0zG1AS)
Steve
